It is currently Mon Jul 21, 2025 5:27 am
PostPosted: Thu Oct 12, 2006 3:11 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
My Stew Mac buffer seems to have a warble on one side. The left
bearing has a knock making that wheel less than smooth to use. The
right side is tight and works fine.
It looks like there is an adjustment collar of some sort on the inside
of the arbor, allen head screw etc. But I haven't had a chance to take
it apart yet.
Anyone have any similar issues? Or a fix idea.
LouisLouis405239003.0086574074
- Louis Freilicher
PostPosted: Thu Oct 12, 2006 4:31 pm
Louis, is this a new buffer?
I found that I had to have the nuts on the right and the left side spaced the same number of threads from the end to ensure it spun in balance; I didn't have any problem with the bearings.
PostPosted: Thu Oct 12, 2006 4:36 pm
Read where I explained how to balance the buffs, also. About a month ago, so it should still be on the board.
PostPosted: Fri Oct 13, 2006 12:39 am
[QUOTE=Mario] Read where I explained how to balance the buffs, also. About a month ago, so it should still be on the board.
You can find that discussion HERE
PostPosted: Fri Oct 13, 2006 9:37 am
First name: Louis
City: Belchertown
State: MA
Thanks for all the info. I'll have a closer look at it this weekend.
Louis
- Louis Freilicher
PostPosted: Fri Oct 13, 2006 2:56 pm
First name: Louis
City: Belchertown
State: MA
I've beefed up my stand, which helped a lot, and I'm working on
balancing the wheels using Mario's guidelines. She's been in and
out; when she's out she wobbles like crazy. It's been easier to tell
when the balance is off.   When it's close I keep thinking I can make
it better and then I make it worse. I’m going to keep at it until she's
right on.
Thanks for the help all.
Cheers,
     Louis
- Louis Freilicher
